How to Create and Integrate the Execution of Purchase Documents in Accounting? (Public Sector)
The expense budgets are particularly important for the public organizations, so it is crucial to integrate correctly the purchase documents and the execution processes in accounting. From version 10, the budget handling is no longer necessary when creating and integrating the purchase documents, and that logic is implemented when saving the purchase documents, when decoding the previous token in the document lines, as well as in the purchase document accounting integration, with the creation, filling in and saving of the corresponding execution process. This article intends to demonstrate the creating and integration of the initial flow purchase document and its transformation to a posterior document, using the engines, following these steps: Step 1 - Add references: Step 2 - Create the initial flow purchase document: The lines must contain the token "<NOVOPROC>" in the "ProcessoCBL" property in order to create a new execution process: Step 3 - Integrate in accounting and create the corresponding execution process: Step 4 - Create the following document by transformation://Creation of the purchase document
CmpBE100.CmpBEDocumentoCompra objDoc = new CmpBE100.CmpBEDocumentoCompra
Tipodoc = "PRC",
Serie = "2020",
TipoEntidade = "F",
Entidade = "F0001",
NumDocExterno = "1"
//Filling in the data related to the document header
BSO.Compras.Documentos.PreencheDadosRelacionados(objDoc);
//Line creation
BSO.Compras.Documentos.AdicionaLinha(objDoc, "A0001");
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).PrecUnit = 10;
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).ProcessoCBL = "<NOVOPROC>";
//Line budget classifications, according to the budgeted plans
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).ClassEconCBL = "01020210";
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).OrganicaCBL = "010403";
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).FonteCBL = "000";
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).ActividadeCBL = "000";
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).ProgMedidaCBL = "000000";
objDoc.Linhas.GetEdita(objDoc.Linhas.NumItens).ContaCBL = "621311";
//Saving the purchase document – includes the token decoding
BSO.Compras.Documentos.Actualiza(objDoc);
try
BSO.Base.LigacaoCBL.IntegraDocumentoLogCBL(ConstantesPrimavera100.Modulos.Compras, objDoc.Tipodoc, objDoc.Serie, objDoc.NumDoc, objDoc.Filial);
catch(Exception exIntCbl)
CblBE100.CblBECnfDocExercicioLigCBL objConfigDoc = BSO.Contabilidade.ConfiguracaoDocCBL.EditaExercicio("C", objDoc.Tipodoc, objDoc.DataDoc.Year);
//In case of a document with a budgetary connection (to create the execution process), but with no accounts to decode, the integration in accounting will return an empty document error.
//In these cases, the exception must be ignored because it is supposed to not integrate - creating the process.
if(objConfigDoc.PlanosDeContas.NumItens>0)
throw exIntCbl;
//Creation of the following purchase document
CmpBE100.CmpBEDocumentoCompra objDocT = new CmpBE100.CmpBEDocumentoCompra
Tipodoc = "COM",
Serie = "2020",
TipoEntidade = "F",
Entidade = "F0001",
NumDocExterno = "1"
BSO.Compras.Documentos.PreencheDadosRelacionados(objDocT);
//Adding a new line, by transformation
BSO.Compras.Documentos.AdicionaLinhaTransformada(objDocT, objDoc.Tipodoc, objDoc.NumDoc, 1);
BSO.Compras.Documentos.Actualiza(objDocT);
//Accounting integration
BSO.Base.LigacaoCBL.IntegraDocumentoLogCBL(ConstantesPrimavera100.Modulos.Compras, objDocT.Tipodoc, objDocT.Serie, objDocT.NumDoc, objDocT.Filial);
