How to manage employee receipts by integration?
Processing receipts for employees is one of the most used features in the Human Resources module. From this operation, it is possible to generate receipts in PDF format with the values related to the allowances earned in the selected period. The receipts processing feature for employees comprehend a range of multiple options that allow to generate custom receipts, for example; This article has the purpose of demonstrating how to process receipts using the engines, by following these steps: Step 1 - Add references To use the objects, it is necessary to apply the following references for the Human Resources engines: Step 2 - Fill in the object with the receipt information To generate a receipt, it is necessary to consider a few configurations that allow to create the PDF, according to the user options. The object "RHPBERecibo" must be filled in with the necessary properties. Step 3 - Fill in the objects with the processing information The employee receipt can have more than one processing type, for example: salary, vacation and Christmas allowances. For that, it is necessary to add the processings regarding the receipt processed to the object created in the previous step. Thus, you should add to the "RhpBERecibo" an object of the type "RhpBEReciboProcessamento" for each processing. Step 4 - Generate receipts in PDF After performing the previous steps, it is possible to generate a receipt considering the filled in object. This operation is divided in three steps: The receipt information will be stores in the database in the table "Receipts", in the field PDF. The meta information regarding the processings used for the receipts is also stored in the table "FuncRecibosProcs".Customize receipts
Process receipts
RhpBERecibo recibo = new RhpBERecibo
CodigoFuncionario = "Código do funcionário",
Ano = "Ano",
NumPeriodo = "Mês a considerar",
CodigoPeriodo = "Código do Período",
Observacoes = "Observações necessárias",
ImprAglomearar = "Validação de aglomeração",
Relatorio = "Nome do mapa, poderá ser RHPR0006",
Moeda ="0"
};recibo.Processamentos.Add(new.RhpBEReciboProcessamento
NumProc = "Numero do processamento",
TipoVencimento = "Tipo Do vencimento",
DataMovimento = "Data do Movimento",
TotalDescontos = "Total de descontos do processamento",
TotalRemuneracoes = "Total de remunerações do processamento",
TotalLiquido = TotalDescontos - TotalRemuneracoes
});PriEngine.Engine.RecursosHumanos.Recibos.IniciaProcessamentoRecibos();
PriEngine.Engine.RecursosHumanos.Recibos.ProcessaRecibos(recibo, false);
PriEngine.Engine.RecursosHumanos.Recibos.TerminaProcessamentoRecibos();
