How to configure the base example provided?
It is available on your installation folder: VKPluginSAMPLESCONFIGSVK3_EKON_Integration, an example of a solution that can be reused as a base example, and that can be customized according to the integration processes defined in the implementation.</install path> This example contextualizes an integration solution between systems ERP - Ekon and VALUEKEEP V3. The solution configuration is defined in the Integration.Config, file with the complete definition of the pipeline execution context. Conceptually, the solution made available as a base example gathers a set of pipeline examples. You should copy the Samplesfile from the installation folder VKPluginSAMPLES</install path> for the installation folder plugin VKPlugin</install path>:
