Valuekeep IntegrationsERP-Ekon Plugin
ERP-Ekon Plugin
Back | List of Articles
What is the ERP-Ekon plugin?
Last changed in 14/01/2025
The Valuekeep Integration ERP- Ekon plugin makes it possible to integrate the ERP Ekon and other systems, for example, the Valuekeep solution. This plugin was designed to use the resources of the Valuekeep Integrator platform and the Ekon API.
Besides improving the integration capability between these systems, thus allowing the implementor and/or integrator to define the integration processes (scalability), allowing to reuse pipelines and roles developed (reuse). The monitoring of the integration processes is also supported by the plugin, using the ERP Ekon information categories.
The execution management and control of the integration pipelines is of the sole responsibility of the Valuekeep Integrator platform.
Note: In order to enhance the use of this plugin, a solution (example) is provided for integration with the Valuekeep maintenance system. This solution is available on the installation folder: VKPluginSAMPLES.
How to subscribe the ERP-Ekon plugin? How to configure the base example provided? Process of material consumption without stock issue in the work order Master data integration process Process of recording misc. costs in the work order
