Valuekeep IntegrationsPlugin v10
Plugin v10
Back | List of Articles
How to download the plugin ERP Primavera V10?
Last changed in 19/12/2024
    The plugin  PRIMAVERA V10 –  Valuekeep Integration installation is performed using the PRIMAVERA Deployment Center.
This option is only available for customers that have subscribed the module VK.INT – Valuekeep Integrator (see PRIMAVERA Licensing). If this requirement is met, you must configure it and install it in the PRIMAVERA Deployment Center, according to the configuration/installation procedures for this service:
  1. Application/platform Valuekeep Integrator configuration:
  2. Module Valuekeep Integrator configuration, available on the application Valuekeep Integrator (we recommend that the installation folder matches the solution installation folder Valuekeep):
  3. Applicational module Valuekeep Integrator, available on the application PRIMAVERA ERP V10:
  4. Installation of the modules configured on the previous items.
After installing, you must use the PRIMAVERA Administrator to:
  1. Add the module Valuekeep Integrator to the companies that require integration services;
  2. Add the module Valuekeep Integrator to the users in charge of the integration services;
  3. Using the API resources requires that the company/user have access to this module.
The plugin installation offers a set of integration examples, available on the folder – <InstallPath>VKPluginSAMPLES – that can be used as a reference when implementing the integration services:
  1. CONFIGS: example of an integration solution;
  2. HASHSETS: examples of hashing files  (version) used on the solution;
  3. MAPPERS: examples of mapping files  (data transformation) used on the solution;
  4. POSTMAN: examples of collections (postman collections) used in API tests;
  5. TEMPLATES: examples of templates (pipeline structure) used on the solution;
  6. LISTSV10: examples of lists (Adhoc) used on the integration solution
The module VK.INT – Valuekeep Integrator requires at least the version 10.10 of the PRIMAVERA products.
V10 plugin overview (Pipelines) V10 plugin readers (Pipelines) V10 plugin mappers (Pipelines) V10 plugin writers (Pipelines) V10 plugin hashing (Pipelines)
