Last changed in 27/12/2024
In the scope of integration, readers use the resources of the lists in order to define and segment the information
applicable to the business process. As a tool for easy use and monitoring of business processes, the plugin adopted the application lists as a transversal reading technique, enhancing the performance of the services.
The plugin provides the following readers that should be used depending on feasibility and technique applied.
- ListReader: uses a list based on an information category. The information transmitted is restricted exclusively to that
provided by the list, including the filters applied; - AdhocListReader: uses a list based on a query, enhancing integration. The transmitted information is restricted exclusively to the information provided by the list;
- FullListReader: uses a list based on an information category. The transmitted information corresponds to a get request from the entity, that is, the list is only used to get the subset (conditional filter);
- FullAdhocListReader: uses a list based on a query, enhancing integration. The transmitted information corresponds to a get request from the entity, i.e. the list is only used to obtain the subset (conditional filter).
In order to enhance the performance of the services, the lists should include conditional filtering based on versioning control (hashing field)
The plugin distributes several sample application lists in: VKPluginSAMPLESV10LISTSPRIMAVERA10_VALUEKEEP3,
which you can explore and use in developing your pipelines.
