Valuekeep IntegrationsPlugin v10
Plugin v10
Back | List of Articles
V10 plugin mappers (Pipelines)
Last changed in 27/12/2024
A service integration solution must be able to easily define data bidirectional transformations, from their native representation to other formats, more adequate for the process integration, such as: XML, JSON.
The ERP V10 – Valuekeep Integration plugin, offers a transformation process (format JSON) with the purpose of mapping the data from the source system to be issued to the target system. This mapping technique uses a Data Dictionary, preserving the original data and the transformed data.
In order to optimize the integration processes, the plugin offers on the installation folder – VKPluginSAMPLESMAPPERS – a set of mappers (json files) that can be used when implementing the integration services.
The syntax and semantics applied is common to both systems and is defined in a model context and easy to interpret.
How to download the plugin ERP Primavera V10? V10 plugin overview (Pipelines) V10 plugin readers (Pipelines) V10 plugin writers (Pipelines) V10 plugin hashing (Pipelines)
