Valuekeep IntegrationsPlugin v10
Plugin v10
Back | List of Articles
V10 plugin readers (Pipelines)
Last changed in 27/12/2024
The readers available on the PRIMAVERA V10 – Valuekeep Integration plugin has the goal of providing the systems (PRIMAVERA ERP V10 and Valuekeep) with mechanisms that reduce the number of requests and allow the implementer/integrator to easily customize the reading requests according to the requested business processes.
The goal of the reader is to identify on the source system, the information subset that requires integration with the target system, preserving service performance issues. For that reason, to improve these principles, the following methodology has been adopted:
  • Hashing System: the information subset is controlled by a hashing technique applied on the source system (see article);
  • Applicational Lists: the information subset result is obtained using the applicational lists, available in both systems (see article).
The following image shows the technique applicable on the plugin to get the information that will be integrated.
How to download the plugin ERP Primavera V10? V10 plugin overview (Pipelines) V10 plugin mappers (Pipelines) V10 plugin writers (Pipelines) V10 plugin hashing (Pipelines)
