IntegrationsPlugin v10
Plugin v10
Back | List of Articles
V10 plugin pipelines (Solution)
An integration solution is made up of one or several pipelines (integration flows). The solution made available as a base example has several integration flows, which can be reused and/or customized according to the business processes defined.
