Valuekeep IntegrationsPlugin v10
Plugin v10
Back | List of Articles
V10 plugin schedulers (Solution)
Last changed in 27/12/2024
The execution frequency for a pipeline is defined using the scheduler on the pipeline configuration. The Schedulers catalog, present on the solution made available as a base example, can be customized by including new items, by using the utility Valuekeep Integrator SDK.
The definition of an Scheduller is synthesized in the definition of two attributes:
  • Id: identification or designation of the scheduler;
  • ConfigStr: configuration string that represents the execution frequency, obtained by using the utility or written in seconds.
How to download the plugin ERP Primavera V10? V10 plugin overview (Pipelines) V10 plugin readers (Pipelines) V10 plugin mappers (Pipelines) V10 plugin writers (Pipelines)
