Valuekeep IntegrationsValuekeep Integrator
Back | List of Articles
How does the configuration file work?
Last changed in 27/12/2024
A configuration (Integration.Config) contains the complete definition of the pipelines execution context.
The platform supports multiple configuration files, that is, we can have more than one Integration.config, that is, it allows each solution to distribute its own configuration file, without having to add a single file to the solution-specific configuration. The platform then reads all the available configuration files and builds a global configuration that results from the merge of all the existing configurations. The global configuration file is processed and created at runtime in the application folder with the name Global.config.
What is Valuekeep Integrator? How to download and install Valuekeep Integrator? What are Schedulers and how to configure them? What is the Valuekeep Integrator-SDK? What are Workers?
